Old 07-29-2014, 03:10 PM
305motorsgt's Avatar
305motorsgt 305motorsgt is offline
Default 1210 Hydro won't move
I have been slowly getting the 1210 I won off ebay back together. The other day I was mowing to see how it did. I started to hear pining from underneath. I shut it down and used a fork lift to pick up the rear to tow it back to the garage. I found the rear drive shaft bolts were broken. The nuts weren't lock nuts so I thought they just backed off and that's how the bolts got broken. So I replaced everything and now it won't move. I move the lever forward and back and no sound from the hydro. What else did I break beside the drive shaft bolts?
Old 07-29-2014, 03:24 PM
Probably punctured the filter. Very common when a driveline breaks. Pull the filter, I bet you find a gouge in it.
Old 07-29-2014, 03:35 PM
Also, check the Spirol Pin on the Coupler to the Hydro Unit input shaft. That pin may have broken too.
Old 07-30-2014, 04:16 PM
It was the filter. I had picked up a new one to do a fluid change in the trans anyway. Thanks for the help.
Old 07-30-2014, 05:43 PM
Nailed it.
