Old 08-05-2014, 09:22 PM
st.johnian26 st.johnian26 is offline
Default 125 Cub Cadet
Have anyone use the rear output shaft on the hydro to run rear PTO for implements? If it can be used as PTO, what implement was use?
Old 08-05-2014, 09:37 PM
to only problem with using it as a pto is the it spins with the motor so there would be no way to shut the pto off, if you could come up with a clutch system for it i dont see why you couldnt put a rear pto on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-05-2014, 09:53 PM
If you could manage to find the rear PTO off a later hydro tractor you could fab it up. But finding one is near impossible, and they usually go for BIG $$$. Secondly, it will turn the wrong way, and too fast for any "bought" equipment. You would have to build your own. Not really worth the time. If you want a rear PTO, it's cheaper to buy a gear drive either with one, or find one and install than to build one for a 125. Still then, same problem. Turns the wrong way.
Old 08-29-2014, 02:54 PM
Default ported hydro
Which one of the ported hydro will fit a cub cadet 125?
