Old 08-06-2014, 08:32 AM
jimbob200521's Avatar
Default Hydro control parts swap; old Cubs saving new
First off, I'm not sure where this belongs so I'll post it here and let the mods decide.
A little backstory
I've been doing a bit of work on a 2284 lately and along the way, I found that I had some trunnion work that needed to be done. However, it was not to the plate that goes into the hydro like is the case more often than not. This time, it was the plate that runs perpendicular to it. It had the typical notches/groves worn into, really messing with my speed control. Since I don't have regular access to a welder, I decided to search for a plan "B" while I find someone who can weld. I had a parts 147 laying around, so the thought crossed my mind to check it's hydro parts out for a swap. After checking partstree.com to compare part numbers, I found that the plate in question has the same part number on a 147 as it does on a 2284. How is that for a good design; all those years and the same control parts!!
The Tear Down/Parts Swap & Problem
So, without wasting time, I grabbed the plate off the 147, cleaned it up, threw a coat of paint on it, and installed it on the 2284. I fired it up and moved the hydro lever. Lo and behold, the tractor started moving, but...I couldn't get past about 1 mph. Hmm...
I looked at the linkages and quickly discovered the problem. It turns out, there had been a small design change throughout the the years. In the pics below, you can see on the left hand side, the part has gone from "pointy" on the 147, to rounded on the 2284.
Resolution/Final Product
This was nothing short of a simple fix. I locked the part in the vice, grabbed my angle grinder, and rounded the corner out. Once I did this, I put things back together and lo and behold, it started moving good as new.
Below are a few pics of the part as is/where you need to round out (lined in red), as well as the part installed with a red line to show where the part was hitting, the problem area. So, for anyone out there, don't be afraid to scavenge your old machines for hydro parts; from what I can tell, they have largely remained unchanged from the first hydros up to the Cyclops Supers. Good luck guys, and happy Cubbing
-Ryan
Old 08-06-2014, 08:52 AM
Great write up. I learned something new today. Thanks.
Old 08-06-2014, 09:40 AM
What Sam said.
Old 08-06-2014, 09:54 AM
rwairforce rwairforce is offline
Excellent pictures as well. Thanks for sharing.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-06-2014, 11:12 PM
Thanks guys, glad I got to learn y'all something today!
-Ryan
Old 08-06-2014, 11:45 PM
Billy-O's Avatar
Billy-O Billy-O is offline
It's one of those little things that happens.... Nice write up! And nice job on the solution.
Plow blade
#2 Cart
QA36 snowthower
