Old 08-06-2014, 04:16 PM
extremewhitetail's Avatar
extremewhitetail extremewhitetail is offline
Default Whats the difference? k161 vs. k161s
I just bought a gasket kit for a k161 and it doesn't fit my k161s. I thought the only difference was the stoke of the piston. S means short block right! Please help!
Old 08-06-2014, 04:43 PM
It is advisable when ordering Kohler parts, not only use the Model number, but the Spec or specification number also. The K-161 is the base model number while the "spec" number identifies the variations.
K-161-S means "electric start".
Old 08-06-2014, 05:51 PM
Roland is correct. There difference in the early VS late 161's is the bore, not the stroke. The gasket should have worked. Perhaps they goofed and sent the wrong one.
The "K" series service manual has most of this info in it. Although, the early K161 (Actually is a K141) there isn't much info on. I only know what I have been told, and read as they are a pretty rare find with the original bore. The block can be bored to accept the new larger piston, and most have already been done.
Old 08-06-2014, 06:02 PM
What gasket was different, the oil pan one?
Old 08-06-2014, 06:38 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
gaskets should all be the same from 161 to a 161s
Old 08-07-2014, 09:25 AM
Thanks fellows for your much needed wisdom. After some extensive reserch (if you will) I found the gasket guy did send me the wrong set. It was suppose to be for a K161 but received a K321 Kit. BIG DIFFERENCE! Again thanks guys for your help.
Not ever having a father to teach me these things sure made it rough, Im glad you all are here.
Thanks
Old 08-07-2014, 09:35 AM
To add....Kohler Spec Numbers are usually five digits in length. For the K-161, it will look like this: 28001, etc. Some spec number can be followed by a alpha character, ie: 28001A, etc.There can be several hundred variations to a base model to reflect the purchasers wants and needs.
