Hey guys i know its been a while since ive been back on here since i got the 582. That was a ordeal, ordered new gas cap, pet cock, carb rebuild kit, fuel pump kit, clutch, and so on the clutch was out when i got her and finally got her fixed then tried to start her she ran at idle, well things got worse...coil was going out and found one new aftermarket and it worked. well then the starter failed...pulled it out put a new one on and problem solved. but things got alot better....done some trading for a International Cadet 60 doesnt have the orignal motor or tranny but does run and looks good ill get pics soon. just been so busy working alot and fixing the CASE and well finally got it fixed for now. figured id give yall a little bit of info on what is going on here lately.
Brandon CC models: 86, 1650, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1978 1650 Hydrostat w/44" mower & 42" IH push blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
