Old 08-12-2014, 08:39 AM
garnold's Avatar
garnold garnold is offline
Default Cub 75 repower
I was given a #75 from a friend. Not completely sure the status of the engine but just trying to get things lined up before I spend to much time on this. This tractor is for my kids to play around with since it's nice and low to the ground and should be simple enough for them to play with. My questions is this, if the engine is shot and since it seems like a bugger to find another what should I be looking for in an engine to repower this? Not looking to keep stock or refurb this, just looking to have some fun and get this running easy and quick Thank you!
Old 08-12-2014, 03:05 PM
Why don't you see if you can get it running before worrying about replacing it.
If replacement is necessary........ any engine that bolts in. It's just a vertical shaft Briggs. Should be pretty easy to find an engine to bolt in. FWIW, those old Briggs run forever.
Old 08-12-2014, 03:13 PM
garnold's Avatar
I totally plan to check this engine out. I'm just having a hard time finding info on it (including manuals) so I wanted to make sure I had some plan of attack here. Since I have the engine's numbers I'll have to contact B/S and see if they can help me. When I type in the numbers from this engine into their site it does not show anything for me. That being said, I'm not to proud to except some help
https://drive.google.com/file/d/0B3t...it?usp=sharing
Old 08-12-2014, 03:21 PM
garnold's Avatar
OK, maybe I could have looked a little harder
https://www.youtube.com/watch?v=Vj-ZYFW8sh8
http://www.manualslib.com/manual/33990/Cadet-75.html
Though I could still use some help with the service manual for this engine
Old 08-12-2014, 05:16 PM
Gene,
You are more than welcome to use this one.It is dated 1984
Old 08-12-2014, 06:28 PM
garnold's Avatar
Thank you Lew :-)
