Old 08-13-2014, 02:18 PM
dpakk44's Avatar
dpakk44 dpakk44 is offline
Default How do you clean your rust bolts?
I'm restoring an O and lots of the bolt are rusty. Is there a quick and easy way to clean them without the time of a wire wheel? Also are there kits you can buy that has all the tractors bolts, screws, nuts, and washers?
Thanks.
1962 cub cadet original
cub cadet 86
Old 08-13-2014, 02:23 PM
Go to the local farm shop or hardware store. They sell bolts and hardware by the pound. Just replace all the bolts. Not worth the time to clean. If you absolutely think you need the original bolts, then bead blasting is the best way.
Old 08-13-2014, 02:28 PM
jkier's Avatar
jkier jkier is offline
I've used a vibratory tumbler for small parts before.
Takes a while but you don't need to stand and watch it either.
Plus I already had one for reloading
http://www.harborfreight.com/5-lb-me...ler-67617.html
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 08-13-2014, 02:54 PM
Mix a solution of 30% muriatic acid, 10-1 with water and soak your bolts. Some bolts will be clean in 30 minutes, some may take a couple hours.
Rinse them off good in clear water, then something like Castrol Super Clean and rinse again and dry quickly or they'll rust.
If you watch it closely, you can pull your bolts out before the acid eats the zinc coating off the fastener and they won't rust then.
Old 08-13-2014, 03:16 PM
My time is worth too much money to take the time to clean a bolt that can be replaced for such small cost. I understand that some people want the IH headed bolt, but so far.... I have never seen a case where it made a difference on the value of the machine, or won more trophy's for having the original hardware. (On a Cub Cadet) If you know of a case where it did matter, I'll bow out of that statement.
Old 08-13-2014, 03:26 PM
j4c11's Avatar
j4c11 j4c11 is offline
You can pull the rust off using an electrolysis bath, all you need is a plastic container and a power source. Instructions on setting one up are plentiful online. In your case, you can put all the bolts in a metal tray , wire up the tray and do them all at once. Just don't wire it backwards, it will have the opposite effect of rusting them more(and quickly may I add).
Old 08-13-2014, 04:53 PM
I've used a tumbler for cleaning gun brass, I just filled it with sandblasting sand and it worked pretty good. I'm with j mech though, I just use new bolts on my cubs that way if I ever have to work on it I don't have to worry about hurting the bolts.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-13-2014, 05:28 PM
cc_bob cc_bob is offline
Not quick but very cheap and EASY, just mix up some molasses and water and let them sit for a week. It won't remove the plating or grease but it will remove all of the rust.
Details here..
http://www.onlycubcadets.net/forum/s...ad.php?t=26163
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 08-13-2014, 09:20 PM
You mean when I repainted my blade last summer and replaced the carriage bolts on the wear strip with Home Depot specials it lessened the value of it? this is awful news.......
Old 08-13-2014, 09:45 PM
LOL! Yes Daniel, your blade is now worth exactly $7.38 less that it was before.
Tags
bolts, cadet, original, suggestions, tractor
