Old 08-13-2014, 11:00 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default 1572 vs 1772 Radiator
I've seen on this forum many posts about overheating problems with the 782D and 1572. I myself, in the years I've owned these machines figured that it was the nature of the beast to run hot. Now that I have a 1772, I noticed it REALLY runs cool and as a test, I let it idle for a while to see if the temp gauge would creep up to hot in the same fashion as the 782D and 1572 always did. The 1772 stayed at the bottom of the temp gauge after extended idling. If I don't bump up the engine speed on the 1572 or 782D to almost mid throttle, I can be sure the temp would creep to the hot zone on the gauge. While looking for differences between them, I noticed the radiator on my 1772 appears to be larger. This may provide enough added capacity to keep it cool the way it does.
Now if you look at the radiator from my 1572 take a look at the size it is, and notice the size of the top tank.
Take a look at the radiator from my 1772, notice that it is bigger and the tank is bigger.
Is there a way to increase the cooling capacity of my 1572 radiator to match that of the radiator in my 1772, short of trying to locate a 1772 radiator which is probably impossible to find?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-14-2014, 12:58 AM
red56turbo's Avatar
I didn't realize they had two different rads in them. Never looked at my 1572 and 1772 while comparing them side by side. Learn something new everyday. I do know they added the fan shroud extension to aid in cooling to some of the 1572's. My 1572 has it. I've seen them without it as well. Boy Frank, I can't think of any way to increase cooling capacity without putting in a larger radiator, which as you stated, would be impossible to find from a donor 1772. Curious to see what others think. Now I'm gonna have to go out and look at the supers and compare rads........
Josh
Diesel Cub Cadets...........
Old 08-14-2014, 05:53 AM
I have not had a problem with overheating on mine yet. They will go up to the right side mark (170*) and then you can see the thermostat open and the temp drop.
I never noticed the difference in size but the 1772 is about 2.25" and the 1572 is about 1.5". I learned something new today.
The 1572.
The 1772.
Old 08-14-2014, 08:09 AM
FrankF3's Avatar
I thought and assumed that they would have used the same radiator in both models. Checking out part numbers for radiators between the 1572 and 1772....
782D, 882, 1512 & 1572 Radiator = KB19488-72060
1772 Radiator = KB19498-72060
Old 08-14-2014, 08:49 AM
hhc70 hhc70 is offline
Frank - That is some GREAT information. Thanks for posting this.
Old 08-14-2014, 01:11 PM
red56turbo's Avatar
I echo Todd as far as the overheating issues. I, myself haven't noticed any problems.............yet.
I wonder if the 1782 has the same sized rad as the 1772?
Josh
Old 08-14-2014, 01:40 PM
These are the part numbers for the radiators used in the 1782 and 2182 both early and late.
KB-12581-72060 1782 early
KB-16861-72060 late
KB-12581-72060 2182 early
KB-16861-72060 late
I know both my 1782 and 2182 run around 190. My guess is the don't get as much air flow as the 72 series do. I'll probably pull my radiators out this fall and have them cleaned at a radiator shop. They are probably getting crappy inside.
Old 05-18-2020, 08:09 PM
FrankF3's Avatar
I was searching for the radiator thread that I started. In looking through the posts above, I noticed Oak said he never had an overheating problem with his tractors. Now I've had over heating with both my 782D and my 1572 but not my 1772. Looking at Oak's post, I noticed the pictures of his machines showed he did not have the extension for the fan installed on either machine. I did not have it installed on my 1772 and it did not overheat either. Is it possible this fan shroud extension could be contributing to the gradual overheating on my 782D and 1572?
Oak, what do you think?
Old 05-18-2020, 09:08 PM
CubDieselFan's Avatar
Does your 1572 and 782D have the insulation on the hose that goes across the top of the engine? My 1572 had a overheating issues years ago and I noticed when it started, the insulation had fallen at around that time. I put foil tape on it and was cool as a could be. I noticed Todd’s has insulation.
Old 05-20-2020, 05:51 AM
Frank, I dont think any of my diesels have the extension. I have not mowed with any of my diesel machines either. When do yours overheat?
