Old 08-15-2014, 03:18 PM
garnold's Avatar
garnold garnold is offline
Default Setting the timing on a 12hp
So I almost hate to even ask this question but where do I look to see the "S" on the fly wheel? I only see one whole on the S/G side of the engine that could help me here but I've turned the crank over and over and only see white and yellow marks? I have a timing light and need to tune up this cub. After this I'll get the carb tweaked as well. I've read both guides in the tech section on this forum but for the life of me cannot find this "S"
Old 08-15-2014, 03:36 PM
It is there. It is probably rusted over making it difficult to see. Sandpaper used to scour away the rust & polish up the edge of the flywheel will help.
Old 08-15-2014, 03:39 PM
garnold's Avatar
Holy cow this was hard to see! So there seems to be some scratch marks above the s. Looks like the PO put them there? Do I use them? One post I read someplace said I should do something like this.
Old 08-15-2014, 04:12 PM
bocephus1991's Avatar
I put white out on my s mark , paint works too
Brian
Old 08-16-2014, 03:12 PM
austin8214's Avatar
Ditch the timing light and follow the procedure in the link.
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Old 08-20-2014, 08:21 AM
garnold's Avatar
Questions on setting timing.
So first let me explain what I have done and then where I'm at. I first gaped the points to 20 like all the guides and manuals say which is to be a good starting point.
Then I found the compression stroke by first (finally!!!) sighting the small S on the fly wheel. With that in sight I spin the fly wheel till I see the points opening up and the S in sight. This was the process I read in one of the guides.
Now by either using a meter or light I'm suppose to rotate the flywheel slowly till either the light goes on using the light method or the meter moves. At which point I see if the S is center in the sight hole.
So before I even ask any questions, am I correct so far? It makes no sense to ask a bunch of questions if what I'm doing up to this point is not correct. If it is then I'll start typing some more
Old 08-20-2014, 08:48 AM
Read these
http://www.onlycubcadets.net/forum/showthread.php?t=14
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
Old 08-20-2014, 08:54 AM
Billy-O's Avatar
Billy-O Billy-O is offline
[QUOTE=garnold;281864]
QUOTE]
Well, yes but NO! When turning the motor, you need to observe the light or meter go OUT! The "S" mark on flywheel is where the point just about open breaking the connection to the test light. Make sure you're turning this motor in correct direction as you do this which is clockwise when you're facing the flywheel.
Plow blade
#2 Cart
QA36 snowthower
Old 08-20-2014, 08:58 AM
garnold's Avatar
[QUOTE=Billy-O;281875]
QUOTE]
Yes, correct this was what I was looking for. The light turning off and/or meter showing now an open circuit which would indicate that the points have now opened. I also turned over the engine and watched the direction of the clutch just to make sure I was spinning the engine in the correct direction
Old 08-20-2014, 09:25 AM
NO........ both wrong.
Read it again. Use this one. http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Put the "S" mark in the window then:
Rock the points closed, then open them slowly with the screwdriver. Just as the points contact breaks, the test light will light.
There are three descriptions that have been linked. I think they are all 3 good depending on you level of ability...... of course I am partial to the one I wrote.
