Old 08-15-2014, 10:31 PM
djrober djrober is offline
Default 54" haban front blade hydraulic cylinder dimensions
Does anyone know the dimensions or an aftermarket listing for the hydraulic cylinder for the front of a 54" haban front blade (CC part# *717-3031)? Thank you.
Old 08-17-2014, 04:15 PM
gdheck's Avatar
gdheck gdheck is offline
I just measured one a couple weeks ago.
Retracted length - 14"
Extended length - 21-1/2"
Rod diameter - 1-1/8"
Tube diameter (excluding the end pieces) - 1-3/4" I'm guessing it's 1-3/8" bore, but 1-1/2" will be a lot easier to work with.
You can figure the rest out from the brackets on your blade.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 08-18-2014, 09:28 PM
Thanks for the info!
Tags
dimensions, haban, hydraulic, plow, sgt
