Old 08-17-2014, 06:54 PM
possompatterson possompatterson is offline
Default Battery?
Ok question - My cub 126 runs pretty good for about 20 min or so then dies. I have to jump it every time you wanna start it. I am pretty sure its not a fuel problem, I cleaned the tank very well. I have new points, set at twenty, new condenser, new coil (all Kohler brand) and correct for my twelve horse engine. So if the battery only holds a charge for a little bit, would that cause it to stop running? With cars I know, they will run off the alternater but will these run off the generator?
Tried to sell my body for cab fair i ended up walking home
Old 08-17-2014, 07:25 PM
Take the battery to a reputable place and have it "load tested", and then we can go from there.
Old 08-17-2014, 07:40 PM
You should be able to run the tractor with the battery unhooked provided the charging system is working. Try jumping it and unhooking the positive terminal and see if it dies.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-17-2014, 08:42 PM
Yes i have tryed unhooking the battery and it dies so i should check the generater correct
Old 08-17-2014, 08:50 PM
IHinIN IHinIN is offline
Either the generator isn't charging, or the voltage regulator is bad. My 100 stopped charging and it ended up being the field wire was broke loose from the post inside the generator.
Old 08-17-2014, 08:58 PM
Possum
You may want to download and read the service manual for the 126, here is the link but I know you are not fond of reading manuals from the last deal we went through.
http://ccmanuals.info/pdf/1x6-7%20Service%20Manual.pdf
Old 08-17-2014, 09:26 PM
Ill download it on my dads lap top tommorow sam mac your rite im not fond of reading manuals they confuse me more then anything and sometimes the info is not correct but ill read it and see thank you for the info
