Old 03-12-2010, 10:42 PM
pepilapeau pepilapeau is offline
Default sleeve hitch install on 782 help
O.K. I recently purchased a sleeve hitch setup for a wide frame cub with brinly hitch. I know some of the parts will work but I am not sure about others? The lift bar is the wrong one but the measurments are the same between holes. As far as I can tell the only difference is the bend? I am also unsure what the small plate ataches to? Any help and pictures would help me greatly. I have a 1982 782 with cast rear end and hydrolic lift if that helps.
Old 03-13-2010, 09:24 AM
FWIW
I did the same instillation on my 782.
I used the curved bar, but I experience that the lift pin in the sleeve
(the one that does the lifting) goes too high, hitting on the sheet metal right @ the IH decal.
It raises the fender assy about 3/4".
So that told me that the center to center holes are a little longer on the curved bar versus the straight bar. I plan to just shorten up this measurement by welding the hole shut and re drilling closer together.
At present, I don't need the hitch so it isn't a priority.
I made a pin to attach the bar to the hyd cyl.
Also I had to remove the zerk fitting as it caused an interference problem.
The square metal with the pin in it, will not be needed as it is replaced with existing cylinder pin ( in my case the one I made)
this is just how I did mine.
Old 03-14-2010, 08:58 PM
Thanks for the info. I will try out the lift bar I have and see how it works. The pin idea looks like it shoud work well. I will try to make something similer.
Old 03-15-2010, 01:33 AM
If you use that lift bar, I can almost guarantee you're going to put a big dent in your fenders. The correct lift bar is just a straight piece of steel with 2 holes drilled in it, one with a counterbore. I might have dimensions around here somewhere...
Old 03-15-2010, 01:55 PM
rwire125 rwire125 is offline
Im in the pracess of fabing up my own lift, and have been told the lift bar is 27" with a 25" center too center hole spacing my last thing to do then weld the arm into position, my thing is these 782 dont seem to have much lift travel and was looking at a deere cyclinder that has another approx 1 1/2" of lift but havent looked into what other issues that could create. pictures too follow.
Old 03-15-2010, 02:11 PM
You should have plenty of lift travel...is there something keeping it from moving through its full range of motion?
Old 03-15-2010, 03:09 PM
I'm with Matt, on the plenty of travel,
Attached is a pix with the lift in the down position on my 782.
You can compare that to the previous post of it in the up position.
I would think it is sufficient movement.
Old 03-15-2010, 10:12 PM
Well I used the lift bar I have and it does hit the rear. I'm not against notching the body to make it work. This is a low budget setup and not a show tractor so it will work fine for me. I was pretty happy with the amount of lift it gives you. I think it will give me plenty of lift for my rear bucket project I am planning. Here are a few pics with the sleeve hitch installed and the rear rims painted with the new tires. I still got to do the fronts.
Old 03-15-2010, 10:46 PM
Do as you like, it's your ride, but on mine, I will shorten the Center to center distance. Just a guess off the top of my head, it can't be more than 1/2"
or so.
Over the years and restoring everything that I have, so many times I have cussed previous folks handi work as well as my own, in my younger days.
If it just takes a little work I take the time.
It hurts when I realise all the things I cobbled or threw away or scrapped that are prized treasures today.
I have modified my 782 with the addition of power steering but not so much as can't be restored to origional with just bolt back on parts.
----Just an ol boys take on things.
Old 03-15-2010, 11:55 PM
murphycc
Guest
Posts: n/a
I'm in agreement with others....nothing worse than a hack job.
Scott
