Old 08-22-2014, 08:10 PM
Catfish449 Catfish449 is offline
Default Flipping Belts......
Hey guys, looking to get some advice from the vast amount of knowledge here. Been a member for a while, but this is my first post (What can I say, I like to read)
I have a 1996 model 1864 that has a habit of flipping the belt from the engine to the deck. All of the blade spindles have been rebuilt within the last 3 years and lubricated religiously........ Every piece of this tractor has been rebuilt at some time or another. Okay, back to the problem........ No restrictions on the deck. Both pulleys on the Mule drive spin freely with the belt off. There appears to be decent tension on the mule drive pulleys keeping the belt tight. I turn the adjuster to even the pulleys out. I am using a Gates Belt Part # L589 (3/4X58") This belt was replaced last weekend for the same reason. Normally, it flips at the Mule Drive, but this one flipped at the Clutch pulley on the crankshaft.
I have been a mechanic all of my life (24 years professionally) mostly mid-range diesel. I am usually pretty good at troubleshooting this type of thing, but this one has me "bumfuzzled" . I am in hopes that someone here has at least seen this before and can help. My son needs to mow, but with belts @ $40 a pop, I would like to do something with this one before it ruins this one. At this point, there are no frayed edges (yet)
Thanks,
Fish
Old 08-22-2014, 08:32 PM
Try a genuine Cub Cadet belt,
What deck do you have?
If it is a 48" or a 54" deck, that is the wrong belt.
The number you list, (L589) does not come up as a "B" section belt. It is not 3/4X58". It is 5/8X89" which is the wrong size. It is the wrong belt, no matter what deck you have.
Need deck info to proceed......
Old 08-22-2014, 08:51 PM
It is a GT48. When I got the tractor after my grandfather died, it didn't have a belt on it. With the Pulley being as wide and deep as it is, I naturally assumed that it needed a 3/4" instead of a 5/8".
Fish
Old 08-22-2014, 11:17 PM
The 48" deck takes a "B" section belt, 91.68" long. You can try a B88 or a B89 Gates. One is a little short, one is a little long. O'Reilly's shows the cross of the CCC part number to a Gates 6757BR, but I'm not convinced. It shows it's a little long. I'd check it. Or...... go to CC and get the right belt, the first time no worries and it will last a very long time.
Old 08-23-2014, 09:58 AM
Thanks for the info J-Mech. I will definitely get a CC belt.
Fish
