Old 08-26-2014, 06:12 PM
Sruscu Sruscu is offline
Default Fuel leak in my 2135
I have a major fuel leak in my Model 2135. I think it will turn out to be in the clamps/hoses between the tank and the fuel filter or the hose immediately after the filter. Is it possible to replace these without removing the rear fender?
Old 08-26-2014, 08:15 PM
If your leak is near the pump, yes you can fix it without removing the fender pan. If the leak is at the tank you need to pull the fenders. Just my 2 cents but your tractor is old enough that you should pull the fenders, give it a good cleaning and replace all the fuel line and filter from the tank to the carb.
Old 08-27-2014, 06:17 PM
Thank you. I will take your advice!
Tags
2135 fuel leak
