I have a 2009 LTX1045. A couple of days ago it stopped moving and the brake pedal would stay in the down position. I finally got a chance to get under it and found that the "Extension Spring" (I think is what it is called) came off of the pulley. I think I see where it connects, so not a hard fix. The problem I'm having is that the drive belt came off of the "Input Pulley" (at the transmission under the hydro fan). The "Belt Disengage Support Bracket" is in the way, keeping me from being able to put the belt back on the pulley. What is the best way to put the belt back on? It appears that the bolt that holds the hydro fan and pulley is 19mm, but I don't have a 19mm deep socket, so I was trying to use a wrench. When I tried to loosen the bolt, the pulley would just spin. Any suggestions would be greatly appreciated.
