Old 08-28-2014, 08:49 AM
yeeter yeeter is offline
Default What color should it be?
Opinions please:
I have a couple tractors that will be made into 1. The first is a 784, yellow, with a Series II engine.
Then second is a 782, red, no engine.
Both are cast iron rear ends. At the end of it I will have dual hydraulics with aluminum rear end and the series II engine. I have either rear end to choose from so was just going to clean them up and use whichever one cleans up the nicest. Also I believe one of them has 1" spindles and the other 3/4" - I was just going to use the 1" spindles. The front grill is a little different on the red one, but otherwise I cant think of much difference.
But: If I keep it yellow it keeps the frame and engine consistent with each other. If I use the red frame, its an older frame which would have originally had a series I, but Im transplanting the series II into it.
Which would you choose?
Old 08-28-2014, 04:24 PM
SGragg SGragg is offline
Inactive Member
The bottom line: What color do you want it to be? That's all that matters...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 08-28-2014, 08:59 PM
cc_bob cc_bob is offline
82 series look awesome in RED.
Why use an aluminum rear, why not put the internals into a cast one while apart?
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 08-29-2014, 12:45 AM
Shaner Shaner is offline
Internals should be the same between the two rears. Supers are the only ones different as far as I know
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 08-29-2014, 08:11 AM
The only reason is, the two choices I have are both Aluminum.
