Old 03-16-2010, 08:12 AM
gazoriginal gazoriginal is offline
Cool simplicity attachments
i have a chance to buy a rear cultivator, 8" disk harrow, 10" plow, dozer blade, & wheel weights for a 60's model simplicity. my question is- it looks like the front of the attachments are set up for a sleeve hitch, does any body know if they will fit a cub cadet? thanks
Old 03-16-2010, 08:33 AM
Any sleeve hitch stuff should work with a little adjustment, the front blade will need tweaking to fit and a subframe to mount to, wheel weights should be bolt ons. Powered attachments will be a different story as the belt setup is different.
doublecheck the pin size on the hitch....
Old 03-16-2010, 09:14 AM
Smile
what pin size- the one that connects the attachment the the hitch? even if it is too small on the attachments, cant i drill it bigger?, if it is too big it might be a little tougher to fix, but i think it is fixable, am i correct, or way off. thanks
Old 03-16-2010, 12:07 PM
Yes, you are correct.
Old 03-16-2010, 05:33 PM
Merk Merk is offline
Does the plow look like this one?
Old 03-17-2010, 06:27 PM
Talking
yes, he actually has 2 of them (10"), disk harrow, row maker, front dozer blade, cultivator, front mount sickle mower, rear tiller, 25lb. 12" wheel weights, and i think i am missing one more. i got the all for $275
Old 03-17-2010, 07:24 PM
ihnick's Avatar
ihnick ihnick is offline
Wow! Now that's a deal. You could probably sell that sickle for a good amount.
Nick.
Old 03-17-2010, 08:45 PM
Smile
yea i had to jump all over that deal. ill pick up the attachments on saturday- i'll try to post pics on sunday
Old 03-18-2010, 01:53 AM
WOW GREAT FIND! I sent you a pm.
Old 03-18-2010, 12:27 PM
Looking forward to your pics, gazoriginal!
Tags
attachments, disk, plow, sleeve hitch
