I have a 1782 with the 60" haban on it. it cuts "ok", but even with fresh sharpened blades, and full throttle, you have to go pretty slow to get it to not miss grass. I'm talking like 1 or 2 setting, and I have to slow down more in turns. Just doesn't seem right to me. this thing oughta eat grass up with the diesel on it and running full throttle. anyone else have this issue? I'd love to speed it up but don't think I can. its the early deck. with the smaller pulley, so can't swap to a smaller one as I don't think one is available smaller.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
Have you checked the engine RPM?
![]() My Haban never cut as good as my Gravely, but, the Gravely is taller, and FASTER!! ![]() BUT, the Haban should cut better than the deck such as one on a 1450. |
Mine works like a dream. I cut 4 acres in about 2.5 hours with a good hill out back. Going up that and throwing heavy grass is the only time I need to back the speed off some
Something is wrong, it should have no problem. The 1782 should have the large PTO pulley on it and an early Haban would have the small deck pulley so you already have it sped up. I'm running an early Haban on my 2182 but I changed the deck pulley to the late style to slow my deck down. I can drop the engine RPMs down to about 1/2 and it still cuts good. Are your baffles in place?
pretty sure they are all there. the deck is in good shape. it has the blades on it with hardened edges too. the engine is running wide open. I've manually checked it.
Sand blades have a smaller "wing", and lift the grass less, they move less air, so as to lift less sand. Sand blades will cut longer, but, not as good as a regular blade. You might want to try standard blades. |
yeah I wonder if they make gator blades for it? may have to measure the wings on it.
When I looked for gator blades, they said they didn't make them for the 60" decks. I also found out that the regular Oregon blades have been discontinued. Your dealer is about your only option now. The Oregon number is 91-442. I just looked and there are some on Ebay and on Amazon right now. I think they were all under $30 versus $70 from a CC dealer.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
This is who I get my Haban blades from, just over $20.00 ea.
http://www.cubcadetpartsnmore.com/m5...-lg-qty-3.html Mowed with my 1782 yesterday, very happy with the cut and it blows the cuttings about 8'.
Did 2 acres yesterday before the rain and the rest tonight!!! woohoo... I actually like cutting grass..Yea Sam that thing will throw some clippings.!!
Remember to clean the baffels and channel in the point to insure the grass has an even flow out. The ONLY complaint I have is the rear wheels will collect grass on them and when I back up it leaves/peals off a flat patch of grass I have to mow over again...Need to make a brush system to keep them clean....hmmm |
