Old 09-01-2014, 07:57 PM
Chevyguy Chevyguy is offline
Default Anti Rattle Springs
I have a problem with the anti rattle springs on my 582 breaking. These are the double hooked springs that clip over the clutch plate and secure it to the rear drive disc. They are breaking just above the hook. I am buying them at the local CC dealer at $2.50 a piece. I just replaced two missing ones last week and I noticed after mowing yesterday another one was broken. I found it on top of the mower deck under the top cover. Is there something else more reliable I could use instead of these springs?
Old 09-01-2014, 08:57 PM
Merk Merk is offline
I don't use them.
Project Uncle Dick
Cub Cadet 70
Old 09-01-2014, 08:58 PM
Take them off and throw them over your shoulder, problem solved.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-01-2014, 11:20 PM
X-2 but make a wish first
Old 09-02-2014, 08:58 AM
PaulS's Avatar
PaulS PaulS is offline
There are likely very few people that have success with these springs. I view them as a great engineering idea that simply does not work.
Old 09-03-2014, 08:18 AM
Ash_129 Ash_129 is offline
Strange thing, maybe not. I have never had a single issue with the PTO anti-rattle springs in my 129. I installed them after rebuilding the PTO about 5 years ago. (They came with the kit after all.)
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 09-03-2014, 09:02 AM
PaulS's Avatar
I never had any trouble with the PTO clips either but I believe he is refering to the actual drive shaft clutch springs for a manual clutch located behind the engine.
Old 09-03-2014, 09:54 AM
The OP is not talking about PTO ani-rattle springs.......
He is referring to the ant-rattle springs on the drivetrain clutch rattle springs. They are on the clutch/3-pin driver. Little annoying rattling things.
Old 09-03-2014, 01:18 PM
jimbob200521's Avatar
I never liked them, annoying little almost useless things. I think that 1050 you have only has one in there, although it may have both; it's been a while.
-Ryan
Old 09-03-2014, 01:27 PM
I think there are couple in there rattling around. They're annoying.
