Old 09-02-2014, 07:54 PM
125 cubowner's Avatar
125 cubowner 125 cubowner is offline
Default Internal brake axles
Ok the question is I have the internal brake axles and am wondering if the external brake discs from a 82 series will mount on the internal brake axles so I can use these axles on a external brake rear
Thank you Doug
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 09-02-2014, 08:07 PM
Thank you Doug
Depends. What tractor did they come out of, and what tractor are they going in? More info needed to answer.
Old 09-02-2014, 08:13 PM
I am building a pulling tractor and bought a internal brake fine spline setup not realizing that i have all external brake trans so I am looking at these wondering if I could bolt these http://www.ebay.com/itm/251615177112...%3AMEBIDX%3AIT
onto my axles
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 09-02-2014, 08:16 PM
That doesn't make any sense. All fine spline carriers used axles with external brakes.
Soooooo....... you bought the carrier, and not the axles?
Again. Need model numbers please....
Old 09-02-2014, 08:17 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
so you'll be using the fine spline axles with the add on discs. the calipers are larger because the disc is larger, so you'll need to use the rotors and calipers from an aluminum rear and they would work. probably be easier to get an internal brake rear
Old 09-02-2014, 08:21 PM
I bought everything axles diff etc. I had a 100 and sold it not thinking I have a 108 and 128 rear and would like to use this setup in either rear
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 09-02-2014, 08:29 PM
dvogtvpe's Avatar
yes you can but you need the matching calipers,
Old 09-02-2014, 08:32 PM
my next question would be is it worth doing
thank you
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 09-02-2014, 09:03 PM
dvogtvpe's Avatar
no, get an internal brake rearend
Old 09-02-2014, 09:31 PM
thank you both
Doug
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
