Old 09-02-2014, 10:29 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default K301 with Delco generator wont charge
I have a brand new voltage regulator and the generator just wont charge even the slightest bit. The amp meter stays right at 0 continually and the battery dies frequently. I eventually tracked it to be the starter generator because there is nothing coming out of the field terminal. After my investigation with a possible prognosis of the issue, I took it upon myself to tear into it and clean it out. I reassembled it, put it back on the engine and still nothing. So does anybody here on OCC know what might be causing this problem? Can it be repaired? Thanks!!
Old 09-02-2014, 11:07 PM
ford4150's Avatar
ford4150 ford4150 is offline
See if this link is what you need. It is a PDF file and you can d/l it.
http://www.ccmanuals.info/pdf/Delco-...G%20Repair.pdf
Old 09-02-2014, 11:17 PM
Got a 404 error when I tried to open it...
Old 09-02-2014, 11:26 PM
Nothing is supposed to come out of the "F" terminal. Battery power goes into it supplied from the regulator.
Sounds like a wiring or regulator problem.
If you tell us what model of tractor you are working on, we can assist further.
Old 09-03-2014, 05:55 AM
ford4150's Avatar
Try this
Old 09-03-2014, 07:11 AM
This is needed to offer proper and further assistance.
Old 09-03-2014, 05:36 PM
My tractor is a 126. Thanks!!
Old 09-03-2014, 05:53 PM
With the engine running at full throttle, what is the voltage at the Battery Terminals..???
Old 09-06-2014, 07:09 PM
Theres about 11.5 volts at the battery.
Old 09-06-2014, 08:27 PM
That is not enough. Your system should put out around 13.7VDC. Did you perform this test..... S/G Test...??
With the engine at WOT and the F terminal grounded out, what is the voltage at the battery under this test...???
