Old 09-07-2014, 01:43 PM
dads70's Avatar
dads70 dads70 is offline
Default K181 muffler help needed!!!!!
i have a model 70 with a k-181 previous owner made a muffler bracket that screwed into the head then welded a pipe to the screw on muffler, its old and rusty.
was thinking out loud, you guys think if i soaked the bolts several says in pb-blaster then tried to remove them it would work? then would the in block screw threads be bad?
id LIKE to screw on a pipe then 90 it out and add screw on muffler THOUGHTS?
Old 09-07-2014, 02:14 PM
How about a picture of this?
Old 09-07-2014, 04:11 PM
cubby102's Avatar
cubby102 cubby102 is offline
Pictures would help us to see what your working with for sure. But if im reading it correctly there should be no problems with your plan
