Old 09-10-2014, 06:30 PM
rickx rickx is offline
Default What's in your... Kohler K Series? Oil, that is!
Reading on site, I saw information on lack of Zinc/Phosphorus in current engine oils. I contacted Castrol to find Zinc content of their 30W. Info from Castrol:
"The actual amount of zinc and phosphorus is not published though it has been reduced in all of the oils with the exception of the 5W-50 which was specially formulated for this type of application.
Castrol EDGE with Syntec Power Technology (SPT) SAE 5W-50 has been recently reformulated to have a boosted level of ZDDP (1300 ppm) to help protect flat tappet cam engines in classic cars. This engine oil is a full synthetic, has excellent cold temperature properties, and has a high temperature viscosity (SAE 50) that is suitable for use in many classic car applications.
However,we always recommend to follow the guidelines of the original manufacturer in terms of API rating and viscosity. If 5W-50 isn't a suitable weight, we wouldn't recommend its use either."
I plan to stick to straight 30W, but may go to diesel 30W or add ZDDPlus:
http://zddplus.com/how-it-works/
http://www.amazon.com/ZDDPPlus-Engin...=zddp+additive
What do you guys use?
Old 09-10-2014, 06:38 PM
Merk Merk is offline
I use Kohler engine oil. It may cost more....Kohler should know what should be in their oil.
Project Uncle Dick
Cub Cadet 70
Old 09-10-2014, 06:42 PM
#1.) Shell Rotella 30WT.
#2.) Penzoil 30WT
Anything....... 30WT.
Old 09-10-2014, 07:02 PM
timbo2's Avatar
timbo2 timbo2 is offline
I can't find the Rotella T 30W in gallon jugs around here.
I see it recommended by alot of posters.
- Tim
Old 09-10-2014, 07:10 PM
I have O'Reilly's order it. Did you look at Wal-Mart? A lot of stores keep it.
We use olive oil,
if it is good for long life in people, it must do the same for engines.
after we eat our salad, we drain our dishes in a collection vessel,
then we strain it, removing the pieces of vegatative matter and wayward macaroni.
Put it in the engine and it smells like Olive Garden on a Saturday night.
Up to 534 and counting...
Old 09-10-2014, 07:13 PM
We use olive oil,
if it good for long life in people, it must do the same for engines.
after we eat our salad, we drain our dishes it in a collection vessel,
Put in the engine and it smells like Olive Garden on a Saturday night.
Is this what your cooking us for lunch?
Old 09-10-2014, 08:37 PM
HoundDog's Avatar
HoundDog HoundDog is offline
I use Cub Cadet Low Ash 30W
Restored 1970 127
1962 Original
Old 09-10-2014, 08:53 PM
Valvoline conventional 30wt
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-10-2014, 08:57 PM
rwairforce rwairforce is offline
30wt of numerous names.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Tags
engine oil, oil, zddp, zddplus
