Old 09-11-2014, 10:06 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default 18 Hp Magnum rebuild kit
Looking for a complete master rebuild kit for an 18 Hp Kohler Magnum from a 1810 Cub. I was looking around and really can't seem to find a complete kit for a reasonable price, so maybe you guys would know where to get one? Thanks!
Old 09-11-2014, 10:25 PM
There is no such thing as a master kit for that motor. There is also no such thing as a "reasonably" priced kit. The KT/Mags are the most expensive motor to rebuild as far as Kohlers go. I do not recommend rebuilding them as you can buy a new CH for a few hundred dollars more than you will have in doing a good rebuild on your Mag. Pats Small Engines is the best source I've found for both parts, and new motors. Have your credit card ready...... LOL!
Old 09-12-2014, 04:04 PM
Well, is there a place where I can get each individual part from? I need pistons with rods and rings along with a new gasket set. I also would like to rebuild the carburetor and the ignition system. Thanks!
Old 09-12-2014, 04:36 PM
Yes..... I listed it above. Pats Small Engines is the best place that I have found. Otherwise, there is also a place on e-bay that sells parts. baktforkids I think is the sellers name.
