Old 09-12-2014, 08:00 AM
GrotenhuisCubs's Avatar
GrotenhuisCubs GrotenhuisCubs is offline
Default Different lengths of needles?
Is there different lengths of needles on k series carbs? I ordered a needle and seat per tractor model and it seems as if the needle I got is too long. I cannot set the float properly. It was late last night and I didn't measure it but it just doesn't seem right
104 puller, 1200 puller, 1450 toy!
Old 09-12-2014, 08:07 AM
What model of tractor or engine are you working on...??
Old 09-12-2014, 08:48 AM
timbo2's Avatar
timbo2 timbo2 is offline
Or what Carb is it? Kohler or Walbro? I think the needles were different.
The new needle should look like the old one sat side by side.
- Tim
Old 09-12-2014, 01:17 PM
It's a black 12 horse in a 1200, just got the tractor not sure if is the original equipment or not. It has the tie rod end style governor linkage. Any help would be great thanks guys!
Old 09-12-2014, 01:23 PM
That doesn't really help. How about some numbers off the carb? Or at least a model..... Is it a Kohler, Walbro, Carter..... Is it a fixed jet, or adjustable? A pic is fine, we need more info.
Old 09-12-2014, 01:27 PM
Adjustable,at work right now I will get a picture or numbers later
Old 09-12-2014, 02:51 PM
Also, need to know what part number you got. No matter what brand it is..... just need to know so we can see if it is correct or not.
Old 09-13-2014, 09:19 AM
It was a kohler carb and the needle was not the problem. I was trying to work on the carb on the tractor so I didn't notice this at first, when I pulled the carb off and turned it upside down the seet had actually backed out about three threads. Never had that happen so wasn't really looking for that. Got it back together and it runs like a champ!
Old 09-13-2014, 10:47 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you just can't rebuild a carb on the tractor, now when you put it back on don't forget to adjust the governor to the carb
Old 09-13-2014, 07:02 PM
Don't worry Don the plans for this motor is to end up by you, as long as my beans and corn yield like they should! I pull and play with mr. Kreif quite a bit and really like the 16 you did for him. We are going pulling together tomorrow, my first go round with this 1200 I picked up we will see what happens!
