Old 09-12-2014, 07:20 PM
garnold's Avatar
garnold garnold is offline
Default Man that hood vibrates!
So now that I finally have my 108 running I find no better way to relax after a long day but to do a few victory laps around the property Always fun to be known as "that crazy tractor neighbor" HAHAHAHA! Anyway, when I throttle her up the thing (manly the hood) vibrates like crazy! I have to get that nice trim work that goes on the section of the hood that lays on top the dash. Is this normal? I'm checking the engine mounting bolts and they all seem tight. Nothing seems to be wiggling all over the place. My 127 has these clips that hold the hood down and my 73 seems to have these little widgets (I have no idea what to call them) that the hood locks onto to stay down. The 108 just has this little spring type thing that really does not pull the hood down but more locks it from opening up. So the big questions would be, is this normal to have the hood vibrate so much and can I do something to lock it down? Right now without the trim work it's really loud when it rattles.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 09-12-2014, 07:27 PM
Under the hood on the dash there should be a piece that held on by 2 bolts, it should be adjusted up enough that the hood is resting on it and not the dash. I also put black door edge guard on the piece which makes the hood fit snug and eliminates 99% vibration your hearing.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2014, 07:31 PM
garnold's Avatar
Any chance you can post a pick of how you placed that edge stuff? I was thinking of getting that edge stuff from Kirk's Engines. Amazon also sells it and it looks like it might help but I'm interested in what you did because even that edge stuff can only help so much. This thing moves!
73 WIP
75 WIP
Old 09-12-2014, 09:54 PM
Here's a pic. If the hoods resting on this and the hold downs are tight you should be pretty good.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2014, 09:57 PM
garnold's Avatar
The rubber covers on those flanges are all worn off mine. Before I start trying things is this something still available?
73 WIP
75 WIP
Old 09-12-2014, 10:02 PM
Not sure I understand your question. The rubber your seeing in the pic is the door edge guard, you can get it at any parts store.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2014, 10:05 PM
garnold's Avatar
Haha I was thinking something totally different :-) Ok cool and thanks.
73 WIP
75 WIP
Old 09-12-2014, 10:06 PM
No problem
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-12-2014, 10:07 PM
You got a single cylinder Kohler. Those things make any cub shake rattle and roll. Hope you can get it tightened down.
Old 09-12-2014, 10:23 PM
kostendorf's Avatar
Your missing some parts there. Here is what I did and it works.
