Old 09-14-2014, 05:18 PM
rbigg rbigg is offline
Default Throttle quadrant needs a fix
My 3205 throttle quadrant needs a fix. p/n 603-0586.
The throttle, when not on full throttle, comes back to idle. Choke is fine.
Does anyone know how to fix this quadrant?
Old 09-14-2014, 06:01 PM
Look in the manual and see if it says anything about it. My guess the throttle lever on the dash is worn out.
http://service.mtdproducts.com/Train.../770-10227.htm
Old 09-14-2014, 08:12 PM
Agreed. Nothing in the manual.
I'm hoping someone has a fix for the throttle quadrant
Old 09-14-2014, 08:23 PM
I don't think that enough people here own that new of a machine that will be able to help you. Figure out whether the friction is in the throttle quadrant itself or if its in the assembly on the engine. If its riveted together you can usually take the assembly and pound the rivets together a little tighter with a hammer and a punch.
Old 09-14-2014, 08:52 PM
I need to check mine for you but I think J is correct. I'm thinking but not 100% sure the tension is in the throttle assembly on the carb and not the dash levers.
Old 09-14-2014, 10:29 PM
Good points. I hadn't thought of it being on the cable end where the tension is. I'll definitely check that tomorrow.
If it's in the quadrant, I'll bite the bullet and pull mine apart and see what it takes to "fix" it.
Old 09-15-2014, 08:28 PM
My throttle cable is enclosed in armour. That's all that holds it in place: clamps on the outside armour. That does not increase throttle cable pressure. Unless I'm not putting enough pressure on the armour to hold the throttle cable more securely.........
I'm not sure what gets the throttle control to slide back to idle. No springs I can find. I'm going to have to think a bit on this one.
It would seem if I can find a small spring and put on the throttle shaft, it might balance out.
Let me get back with you guys after a few days.
Old 09-15-2014, 08:32 PM
Calvins66Cub's Avatar
Can you post some pictures?
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 09-15-2014, 08:54 PM
Sure. I'll get some pics.
Old 09-15-2014, 09:05 PM
I've seen a little thing that fits over the cable with a bolt in it that bends the cable and in so doing puts some resistance to the cable sliding. Not sure what it's called, maybe someone else can help.
