Old 09-16-2014, 01:58 PM
jim44 jim44 is offline
Default My new 1970 127
Just bought a 1970 model 127 the other day. It seems pretty complete and pretty original, and in good condition. Just a couple questions though. The seat on it is a plain metal seat with holes in it like the real old tractors and implements used. Most pictures I've seen show a padded seat. Is this the wrong seat, or is the padding part just missing? Also the turn radius seems very large, probably something like 20' I'd say. Is this normal?
I have not had time to mess with it very much other than just riding around up and down the driveway.
Thanks for your help and understanding.
Old 09-16-2014, 02:19 PM
Sounds like the wrong seat. The cubs never have the greatest turning radius but yours seems a bit large, I'd adjust everything and make sure its turning freely and see if it helps. You can download the manual in the tech section.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-16-2014, 04:45 PM
TheSaturnV's Avatar
^^^Agreed.
My 147 (basically the same machine) actually has a pretty decent turn, so yours sounds like it needs a tweak. As far as the seat, it would have been padded originally, and it would be obvious if the pad was simply missing. Sounds like someone tossed on an old substitute.
Here are a few good candidates for that machine: (I bought the one pictured last, from Cub Cadet. Not cheap, but I really like it on the 127/147's.
Northern Tool
Hoober
Cub Cadet
Old 09-16-2014, 06:50 PM
bolivier's Avatar
bolivier bolivier is offline
Many people on here have been using this seat. I will probably get a couple of them next summer. Only $84 shipped.
http://www.ebay.com/itm/NEW-SEAT-FIT...item4626dc8ef0
Old 09-16-2014, 07:09 PM
HoundDog's Avatar
HoundDog HoundDog is offline
Originally Posted by TheSaturnV View Post
^^^Agreed.
Northern Tool
Hoober
Cub Cadet
I have the same seat on mine too. (3rd one down).
Restored 1970 127
1962 Original
Old 09-16-2014, 08:29 PM
Wow I didn't know they made the 6 pad still, looks great. I bought one identical to the first pic from northern tool when I redid my 127. The ebay one looks good too.
The correct one is more of a mid back with small lines all over it for the 1#7 series correct? Yoda you got a pic of one?
Old 09-17-2014, 01:06 AM
TheSaturnV's Avatar
Alvy, yes that 6-pad is actually still available directly from the Cub Cadet website. I got mine elsewhere but it was still around $130. You are correct in that the mid-back seat is technically more accurate. The image on the middle seat has since disappeared, but I think it's the closest I've ever seen to the OEM that had all the lines impressed in the surface. hoober.com is where I found that pic.
Bolivier, you cannot go wrong with that seat you posted. I put one on my 882, rugged and comfortable.
Old 09-17-2014, 09:34 PM
The 6 pad is my favorite seat.
Old 09-17-2014, 10:16 PM
Yes I do yes.
Old 10-20-2014, 12:31 AM
SS5150's Avatar
SS5150 SS5150 is offline
Anyone know the part number of that 6 pad seat? Or a source besides CC? I'd like to put one on my 86.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
