Old 09-22-2014, 09:34 AM
FYN409 FYN409 is offline
Default Original Clutch issues
So still working out all of the bugs in my new to me original. Moving on to the clutch. So it sat for many years and the clutch was "stuck" when I got it. Left it in gear, pushed in the clutch and rocked it back an forth a bit and it started to roll.
So now that I have it running I push in the clutch but the drive shaft continues to spin. I can get it in gear but the gears grind a bit. Once in gear the tractor stays stopped with the clutch pushed in. At first I figured it was just that the clutch was just a little sticky yet. Drove it for a while, engaging and dis-engaging the clutch to work it a bit but still no change.
So did a deeper investigation and found with the clutch pushed in the pressure plates do separate from the belt pulley. But when trying to manually turn the drive shaft there is a fair amount of resistance. I also notice a fair amount of "slop" in the belt pulley with the clutch pushed in.
Did some digging and found a clutch diagram and studied it a bit but I am a bit baffled at what would be causing this resistance with the clutch pushed in. Any recommendations before I pull the entire clutch assembly?
Thanks,
Ryan
Cub Original (1961)
Cub 126 in the process of restoration.
Cub 127
1968 Minneapolis Moline Jetstar 3 w/loader
1965 Minneapolis Moline G1000
1952 Ford 8N w/Loader
1942 Farmall M
1936 Farmall F-12
1931 Rumely 6A
1929 30/50 Rumely Oil Pull
Old 09-22-2014, 09:42 AM
Had the same problem on my O. Plan on pulling it out and cleaning up the plates and the pulley faces. It actually is not that hard to get it out and apart.
Old 09-22-2014, 11:40 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
There is a grease fitting on the clutch release. Have you tried grease yet? I would pull it out and go through the whole clutch assembly clean and lube all the bushings and bearings. Good luck. Here Is a pic of my daughters that I recently repaired.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 09-23-2014, 09:03 AM
mmzullo mmzullo is offline
http://www.partstree.com/parts/?lc=c...&dn=0118500010
Here is an exploded view of the clutch. There is a needle bearing on the shaft that runs under the clutch disc that is probably frozen. If that is siezed or tight it will make the clutch disc spin. It's a long time since I had 1 apart but the picture said it's a bushing but I thought it was a bearing. Be careful with the friction material dont get too much oil on it. You'll have to take it apart to free or replace it. I think #8
Old 09-23-2014, 10:09 AM
Down load the service manual, go to page 16 it shows how the clutch goes together, here's the link.
http://www.onlycubcadets.net/forum/s...ead.php?t=4645
The clutch disk has a bushing in it not a bearing, it's part #8 in the parts tree pic.
Tags
clutch, original
