Old 09-25-2014, 02:18 PM
Xaveryptak Xaveryptak is offline
Default Double blades out of alignment
I have LTX1142 with double blades timed deck. After mowing a piece of carpet the blades started to hit each other. I got new blades and attempted to install them. The trouble is that if the two arrows on the pulleys are aligned as per manual the blades are in wrong position. If I align the blades @ 90° the arrows are off. Can I still install them like this or what do I need to do to align both blades and arrows? Thanks
Old 09-25-2014, 02:35 PM
I'm not familiar with that particular model but most older cub decks have a key to keep the pulley and spindle aligned, if so it possible you sheared off the key which let the pulley turn on the shaft.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-25-2014, 04:02 PM
The machine is 2-3 yrs old with 42 deck.
Old 09-25-2014, 06:16 PM
Don't know much about your deck but I think I recall that Cub had problems with the timed deck. You may want to dig a little deeper. If it was my deck I'd just set the blades 90 degrees apart like the old decks and go for it.
Old 09-25-2014, 09:26 PM
dale c. dale c. is offline
try putting them on at 90 degree and try to turn one blade while holding the other and see if something slips on the keyway and changes the time of the blades
Old 09-27-2014, 12:57 PM
Thank you all for your advice.
I am trying to understand how does all this work. Something must have slipped so I am trying to figure out what: a pulley or something inside the spindle. I was hoping somebody would know before I start taking everything apart.
Old 09-27-2014, 01:42 PM
remove the deck from the tractor and try removing the pulley from the spindle, most likely its keyed and it stripped the key out.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-27-2014, 04:29 PM
Here are some pics of my deck:
How do I get off the nut off the pulley? Just like a regular nut - counter-clockwise?
Old 09-27-2014, 08:04 PM
Yes you should be able to remove the nut as usual and hopefully the pulley comes off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-27-2014, 08:46 PM
Moark Willy Moark Willy is offline
Considering you know what caused this I suggest you take the deck to a dealer and let them fix it. It's a 15 minute job at the most and they can look for other problems. It's always a good idea to pick up debris instead of trying to mow it.
Tags
42", alignment, blades, deck, ltx
