Wanting to do all I can to make sure I have no break downs with my snow thrower this winter (if we get any snow).
During the week I don't get much time to do any work for myself but last week I did squeeze some time out to get this thrower disassembled. This weekend I cleaned all the paint and rust from the inside of the housing and the chute, got a couple coats of paint back on them and two good coats of slip plate, I got the flutes on the auger straightened and I got the old grease in the gearbox cleaned out. I am very pleased that there is nothing on this thrower that is worn badly, just a few things that were starting to show some wear. I have checked all related parts for breakage/wear and the only things I could find were, the transfer shaft was a little galled, the small sprocket was a little loose on the shaft, the key-way in the gearbox output shaft was wollered a little, the chain was pretty rusty and a little worn and the auger bearings didn't feel very good. All the parts that are going to be replaced are either here or ordered and on their way. I have a good little bit of welding to do this week so I will try to get ski's welded onto the "runners" and some braces welded to the ends of the flutes on the auger to give them a little extra strength. I'll try to get some more pictures loaded this week as time allows. Please understand that this is a "refresh" and not a "restore" for the time being, I'm not too worried about how this blower looks, for now it's all about how well it works.
Auger Before
Auger after
You are doing a great job, buddy!!!
Keep it up and I will be sending mine to you for a refresh, too. ![]() You did do a really nice job straightening out the auger. Any tips that you could share with me to do the same? Heat and a hammer or heat and ...??? Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Good job on the auger,
![]() It's always good to know that a piece of equipment is going to work when called upon. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
I just used a hammer and a 24 oz hammer head as a dolly.
In all fairness, it straightened out a lot easier than I thought it would, but it did take some time (probably about 3 hours, but not working very hard most of the time). I have another one that is a considerable amount worse than this one was, I thought it would be junk, but as easy as this one was to straighten, I may end up refreshing it one of these days too.
![]() Quote:
![]() ![]() Thank you and glad I could help you out. Jeff |
Jeff made me a new transfer shaft too, ant it's terrific! Many thanks!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
![]() Quote:
One ( as pictured above ) at 4-21/64" long and the other at 4-1/8" long. ![]() |
you are too modest! My auger had some bad spots and I banged on it quite a bit and never got it looking as good as yours. Nice work.
Cub Cadet 147, 149, front blade, brinley plow and cultivator, QA36A snowthrower |
