I am needing to put a sealer on my trailer deck boards for the first time and was interested in what you all have done, what product you have had the best results with.
Thank you for your time.
Aaron '83 782 #723927 ****original KT series 1 engine ****added dual hydraulics from older, donor 782 '04 SRC621 '95 Magnum (M18S) spare engine ****spec 24646 ****s/n 2507913316 |
You might try sealer meant for house decks. It is usually good for 3-4 yrs.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I am sure this will cause some controversy, but, used motor oil is a great wood preservative. And, it's free. I painted a fence with it. after 7 years the wood looked nearly the same. Albeit we don't get much rain here, it was more like adding sunscreen.
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
I just did my 7' by 16' Landscape trailer using a gallon of Thompson's Waterseal- Clear, $17 at Wal-Mart. I used a 1/2" nap Roller and a disposable plastic tray, disposable gloves too. 15 minutes and I was done, throw everything but the roller handle away. I had already pressure washed it and let it dry for a few days. The last treatment lasted about 3 years and it sits outside year round.
That's all we ever used on hay racks and the lowboy trailers.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
If your going to seal it you need to wait abut 6 months for the wood to dry . It's just like building a deck with new treated lumber.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
This thread is kind of a relief for me, I thought I was the only one having trouble with this cheap a$$ treated lumber rotting away.
Where are you finding it cheap???
"If I can't fix it, I can screw it up so bad no one else can either" |
I used thompsons water seal that was honey color, just did it a few weeks ago. I used a pump up sprayer and was done in a few minutes.
No one said it was treated lumber, or green lumber.
