Old 10-08-2014, 10:30 PM
imnotacollector imnotacollector is offline
Default 782 hydro leaks
I was just curious if anyone has any advice on replacing the seals on the hydro pump? It looks as though the seals are leaking at the input shaft, front and back, and I don't know the name of the other shaft that the trunion is on but it looks as though both sides of it are wet as well. I can get a whole new (used)rear for 40$, just wondering if it would be easier to fix than swap. Thanks
Old 10-08-2014, 11:10 PM
It looks like it's leaking from those areas? Or you know it's leaking in those areas?
Sometimes one leak over time can make it look like it's coming from numerous spots. If it was me, before going through a lot of extra work, I would remove the fender pan, and pressure wash everything around the rear and pump, and make for sure where the leak is coming from. Then you can isolate the leak and fix accordingly.
Old 10-09-2014, 08:05 AM
Maybe this will answer some of your questions.
http://www.onlycubcadets.net/forum/s...ad.php?t=21261
They are not all that hard to do. Download the service manual and read it. Holler if you have questions.
Old 10-09-2014, 01:17 PM
yeeter yeeter is offline
I liked the suggestion someone had here to clean it up, then sprinkle baby powder on it all. Helps ID source of the leak.
Old 10-14-2014, 08:10 PM
Sorry it to so long to update, it's deer season, anyway thanks for suggestions, it appears it maybe the cork gasket leaking not the seals. Thanks again.
Old 10-15-2014, 09:29 AM
PaulS's Avatar
PaulS PaulS is offline
Replacing the cork gasket requires the removal of the Hydro unit from the rear of the tractor. Those that I have replaced required moving the engine forward, removal of the driveshaft and brake connections along with the hydro controls. Then you can get to the hydro bolts and remove it. I would suggest that you determine if any of the other seals are leaking/seeping and replace them while the unit is out. A leak at the hydro is many times hard to find because of the hydro fan blowing the leakage all over the place. Replacing the cork gasket is a cheap job but a bit labor intensive.
