Old 10-09-2014, 09:38 PM
OldCubby OldCubby is offline
Default Adding Hydraulics to my 1250...what ports?
So I bought the hydraulic linkage from Bolivier with everything, minus the hydrostat with the ports. Can someone point me in the direction on what ports I am looking for? What is compatible with my model?
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 10-09-2014, 10:21 PM
In order to add hydraulic lift to your machine, you have to have a ported pump. If you aren't sure if your pump is ported, post a pic of it. Easier to tell you, than to explain how to tell the difference between ported and non.
Old 10-10-2014, 06:09 AM
This may help..
Old 10-10-2014, 07:04 AM
Ohh mine is certainly not ported. But, are there different makes to these pumps that won't work my with my rear axle? Or will all ported hydro pumps work?
IE:
http://www.ebay.com/itm/Cub-Cadet-Po...item2ed7a88141
Old 10-10-2014, 07:25 AM
IH used three (3) Sundstrand Hydro Units.
(A) Non Ported
(B) Ported
(C) SGT ported
Any IH Ported Pump will work.
Old 10-10-2014, 07:38 AM
(A) Non Ported
(B) Ported
(C) SGT ported
Excellent! What is SGT Ported?
Old 10-10-2014, 08:21 AM
Super garden tractor
Old 10-10-2014, 09:16 AM
ok, so can ported pumps have either manual or automatic relief valves? Or do they have to be one or the other? The reason I ask is, I just bought brand new relief valves, automatic, for my current non ported pump. I'd be disappointed if I can't use them in a ported pump.
Old 10-10-2014, 09:27 AM
The valves are interchangeable. Yes, they will work.
Old 10-10-2014, 10:25 AM
bolivier's Avatar
bolivier bolivier is offline
Don't some pumps have a splined shaft for the drive shaft, and others have a non splined shaft? He would want one without the splined shaft, correct?
