Old 10-13-2014, 11:30 AM
ford4150's Avatar
ford4150 ford4150 is offline
Default Oil pan gasket K321, K341..??
What's your personal foolproof, no leak, gasket sealant. I've been using Permatex high tack. Just had one leak on me.
Anyone use black RTV?
Old 10-13-2014, 11:43 AM
cubs-n-bxrs's Avatar
I use old school stuff called Indian Head gasket sealer. Has never let me down yet. Most auto stores carry it.
Old 10-13-2014, 12:31 PM
I just use a gasket. Installed dry. No leaky, leaky.
Old 10-13-2014, 01:28 PM
ford4150's Avatar
Seems the sealing surface on my aluminum oil pan wasn't exactly flat. Thicker at the corners. Hand sanded with 120 grit on plate glass for an hour to get it relatively flat.
Dry? Well, I'll give that a try.
What torque on the bolts? I used 176 in-lbs. Threads were clean and lubricated. Ran a bottoming tap in the block and new grade 5 bolts.
Old 10-13-2014, 01:38 PM
Common sense tight. Or about 20ftlbs. 25 maybe. I'm sure it's in the book.
Old 10-13-2014, 04:32 PM
bocephus1991's Avatar
I put mine on dry to. Torqued to 30ft lbs I've pulled them to look inside and inspect and reused the old gasket and used some black gasket sealer, just a thin coat.
Brian
Old 10-13-2014, 05:53 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
same here, dry. common sense tight
Old 10-13-2014, 07:06 PM
sawdustdad's Avatar
I've been using a very thin coat of black rtv on both sides of the gasket. Kind of the "belt and suspenders" approach. No leaks.
Old 10-13-2014, 07:26 PM
dvogtvpe's Avatar
in My opinion RTV is a poor choice of sealant. most people get carried away with it. once you've seen damage from RTV you would understand what a poor choice it is. you also need to make sure there is no oil on the parts or you'll probably have a leak. Hi tack & copper coat isn't to bad if you have to glue something in place. Loctite gasket eliminator is pretty good stuff but its not for use with a gasket. putting these engines together isn't rocket science so KISS (Keep It Simple Stupid) applies
Old 10-13-2014, 07:49 PM
Couldn't agree more on all aspects. Seen all to many failures from the use of RTV.
