Old 10-13-2014, 04:44 PM
RedHawCadet RedHawCadet is offline
Default QA42 question
I just acquired a QA42 snow thrower, thanks Nitro. Do they have to be bolted on or is there a way to use the quick detach on my 73?
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 10-13-2014, 08:53 PM
It has to be bolted in place.
Old 10-13-2014, 08:57 PM
But you make a cool little piece that makes it easy!! You forgot that part Jeff!
Old 10-13-2014, 09:54 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
click for larger view
Old 10-13-2014, 09:58 PM
This cool little piece wouldn't be a rod similar to the one that goes through the mule drive would it?
Mark
QA42 snow thrower
42in front blade
Old 10-13-2014, 10:04 PM
Nevermind..... very slick!
Mark
QA42 snow thrower
42in front blade
Old 10-13-2014, 10:15 PM
It's a piece of metal with a 1/2" rod that keeps you from having to fumble with another nut, bolt, washer and lock washer. Slip it in place and a single 1/2-13NC bolt and lock washer make life easier
Old 10-13-2014, 10:39 PM
A qa 42 uses the quick attach on a 73, no need for those brackets.
But i use bolts on the front holes for extra security.
Up to 530 and counting...
Old 10-14-2014, 07:29 AM
That's how I thought it would work to look at it, but the quick detach latch wont clear the 90 degree box.
Mark
QA42 snow thrower
42in front blade
Old 10-14-2014, 08:55 AM
Once you have the belt on it will.
there is a installation manual in the tec section.
