I want to pull the pan back off and check something on my k301 I'm rebuilding. Can I reuse the pan gasket ?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Nope, generally you never reuse gaskets.
-Ryan
If it is not damaged, I would.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
Agreed. It should be fine. If it's wet with oil, then no. Those Kohler gaskets don't do well after they've been wet with oil. For example, recently, I replaced a breather gasket. Don't remember why, but I had to take the cover back off after running the motor for a short time. Used the gasket I had just installed over...... and it leaks. It got oil on it when I removed it. SO, if you keep it dry, your fine. If it's oily, don't risk it. It's a pain to pull the motor to change the pan gasket.
Ok that answers my question! It will prob have some oil on it from assembly . Yeah I sure don't wanna have to pull it again because it leaks! So will get a new gasket. I am getting good at pulling engines now! Thanks guys!
