Old 11-01-2014, 08:53 AM
Default CCO's and plowing?
How good are the Original's at plowing? I'd like to get an Original and a plow in the future and wondered if anyone has tried that set up. Does the drive train slip at the belt, how much, if at all?
thanks
Old 11-02-2014, 07:21 AM
cubs-n-bxrs's Avatar
I am going to say that they do not slip if all components are adjusted properly. I have seen many O's at plow days pulling land plows and keeping up with the bigger HP tractors. Whether it be a land plow or a snow blade they do just fine. Traction would be the issue if anything. Enough weight on the rear tires and you are good to go.
Old 11-02-2014, 08:19 AM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
^ X2. I tried to snow plow with one of my originals, turf tires no extra weight. It did not work well, no belt slippage but I could not get enough traction to move much snow. If you attempt plowing weight it heavy and chain up.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 11-02-2014, 10:37 AM
Berwil's Avatar
Berwil Berwil is offline
I've pushed snow with the blade on my O for a few years. It was my only snow removal machine for a while, and it works great. I have chains and weight in the box on the back and I was able to build 3-4' high piles of snow. The only belt slippage I've had is from trying to move too much snow...let's just say I was not using the proper plowing technique at the time. For normal snow removal the belt is a non-issue.
Bill
Old 11-02-2014, 03:48 PM
I was talking about plowing- like dirt mould board plowing, not moving snow with a blade.
Old 11-02-2014, 04:28 PM
Like I said in my previous post I have witnessed many O's pulling land plows with no problem what so ever.
Old 11-02-2014, 04:59 PM
Thanks....
Old 11-11-2014, 05:28 PM
David Reinhardt David Reinhardt is offline
I plowed in the garden with my CCO before the cold weather comes .
Old 11-11-2014, 10:07 PM
Good looking O you have there, all the goodies on that one.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 11-12-2014, 09:11 AM
Thanks I enjoy using it. It did a good job plowing. I have a video plowing the garden if I could figure out how to post it.
