While using the blade on the 1450 to push some small limbs and needles from some pine trees, I ran into a small problem. I did some pushing and when I lifted the blade and backed up the blade dropped. This is what I found(see pics). The pivot pin dropped out. It looks like it was originally welded in, is that correct? Also the lower gusset is only welded on one side, should that be welded to both sides? I think that is the reason that the metal is tearing just behind the gusset on the welded side. Thanks for any info, cjet69.
CC 1450, 44A deck, #2 tiller, 42" plow/blade CC 124 CC 1220 #2 Cart |
Yep, you need to do a little welding or have it welded. You should have a nut on the bottom of that pivot rod and it should be welded at the top and it should be welded on both sides at the bottom as you mentioned. Yours was probably built late Friday afternoon.
Or on a Miller Monday morning
or thirsty thursday
Pulled it down, welded it up, and put it back to work. I'll clean it up and paint it sometime later on. It works better and feels more solid than ever. Got most of my clean up project done after the repair.
Looks good. There can be a lot of impact on that pin when the blade trips and slams back into it. I had to get mine welded up last summer.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Nice job repairing it! Nothing like a bunch of great machines hard at work!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
