Old 11-16-2014, 05:41 AM
cdlong's Avatar
cdlong cdlong is offline
Default Another hydro leak on the 1450
I saw oil on the floor yesterday. I pulled the tunnel cover and the top of the hydro was dry. I cleaned the hydro. When I parked the 1450, I placed white oil absorbent pads under her. This morning I have what to me is a lot of oil on the pads. When I wiped my hand across the bottom of the hydro, I had oil. Where would the hydro be leaking when she just sitting? I haven't used her in 2 weeks. Need to get her ready for snow plowing.
Thanks
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 11-16-2014, 07:16 AM
cubby102's Avatar
cubby102 cubby102 is offline
Sounds like cork gasket or trunion seals. Possibly the pickup tube as well.
Old 11-16-2014, 03:56 PM
cdlong's Avatar
By cork gasket, I assume you mean part # 26 on the diagram. The red light shows where I think the oil is coming from.
Papaw
Old 11-16-2014, 04:05 PM
Nope, the cork gasket goes between the pump and the trans case. #23 in this pic
Old 11-21-2014, 05:38 AM
cdlong's Avatar
Haven't been able to check the tractor until this morning. I have oil on the floor again from where I thought. Thanks Sam for the info on the gasket. Any one tell me how hard this repair will be? Do I need to separate the tractor?
Thanks
Papaw
Old 11-21-2014, 06:32 AM
cubby102's Avatar
Sorry I didnt see your reply. It is much easier to pull the rearend out I just did this on my 1450 a couple Mont back a bit of advice is to pressure wash the rearend before you pull the pump off. I do believe there is a writeup on here that can walk you through it. Its only held on with 4 bolts
Old 11-21-2014, 09:26 AM
sawdustdad's Avatar
I've replaced that gasket without splitting the tractor. Remove the tunnel cover and the fenders, and you'll have access.
Old 11-21-2014, 11:12 AM
Just did this last nite, I've got mine split in two though. Gasket was in pretty sad shape after 40 yrs.
Old 11-24-2014, 10:16 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Check out the end cap #29 as well. My 1450 leaked around this end cap because there was a small leak around the edge from rust. I also change the hydro gasket but a few days later the leak started again. It was hard to tell at first.
Old 11-24-2014, 05:27 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
I believe my 149 is leaking from the end cap #29. How did you fix the problem?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
