Old 11-17-2014, 12:53 AM
gdheck's Avatar
gdheck gdheck is offline
Default Mounting a 1991 and later Haban blade on a cyclops?
Since I'm having some trouble with my 2072, which is now known as "you dirty sob" . I thought I would mount the Haban blade on the 1782. I took the leftover rear mounting brackets from the older style 60" mower on the 2072 to the 1782, but the front 1/2" or so is blocked by the footrest. Is it normal to relieve the footrest so these brackets can bolt to the frame or are they normally mounted another way? I see there is a newer style bracket listed for the blade, but it looks like there would be the same problem.
Thanks,
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-17-2014, 06:41 AM
Trim the foot rest's. I do it on my Cyclops Supers when I put the rear end brace on them.
Old 11-17-2014, 10:46 AM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
I didn't have to cut either piece on my 2182 with the haban blade. If had to cut any thing, it would be the mounting plate. Sorry, I don't like cutting up my tractor. Pics of original mounting set up on a 1992. Note my plate is 9.5 x 4.5 inches and mounts different than the one pictured. Hope this helps.
Old 11-17-2014, 03:28 PM
gdheck's Avatar
Well, since I will be putting a Sam Mac brace on the 1782, notch the footrest it is. Don't worry PGHsteelworker, no hack jobs allowed on my Cubbies. It will be done nicely or not at all.
Old 11-17-2014, 03:37 PM
The brace has the Haban mount hole in it already. I'll get you some better pics of how much you need to trim. It's minor.
Old 03-11-2015, 11:48 PM
gdheck's Avatar
As an update to this, Aaron at Xtreme now has the correct 1991 and later Haban blade rear brackets for sale for $28.00 per pair. I'm also going to send him a revised drawing that includes the extra hole for Sam's rear end braces.
Old 04-19-2015, 03:38 PM
Group_44's Avatar
Group_44 Group_44 is offline
I finally found a 54" snow blade ,after a 3 hour round trip and $300 later I have it home. The blade is marked 761-407,is that the same as a 190-401, it came off a late 2072. I didn't get the rear brackets but as far as I can figure it is supposed to use the 91 and later style. I also intend to install the SGT axle brace. My question is.... do I have use the new style Haban bracket from xtreme with the axle brace, or the old style brackets that come with the brace? I have an email in to Aaron but I know he is busy this time of year and it may take a while to get an answer. Are the older square bracket and the new rectangular bracket interchangeable , I want to be able to swap from the 60 deck to the plow depending on the season.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 04-19-2015, 05:27 PM
gdheck's Avatar
If you're putting it on one of your Cyclops tractors, then yes you need the new style brackets if you don't want to notch the fenders. I'm not too sure Aaron has the extra hole in them for the axle brace and they are just 1/8" like the originals. When I get a chance, I'm going to drill the extra hole and have him make some out of 1/4" like the braces are. As far as I know the new style bracket will on older machines, but the square bracket is not just a bolt on for the cyclops'.
Lets see a picture of your blade. I think 407 is what's on my newer style blade. I just drove about a 5 hr. round trip to get one with power angle last monday, but I won't say what I gave for it for fear of starting a riot.
Old 04-19-2015, 07:38 PM
Group_44's Avatar
This is a picture of the plow before it was removed from the sellers tractor. I got am email from Aaron , it doesn't look like he has made the required hole in the new style bracket yet.
1641 w/48" Deck
Old 04-19-2015, 10:03 PM
gdheck's Avatar
I can't see the rear bracket, but if it bent upward like #16, it's the newer style.
New style
If it has the triangular rear brackets like #18, it's the older style.
Old style
