Old 11-18-2014, 08:46 AM
johnpded johnpded is offline
Default 2182
I recently purchased a 1995 2182 Cub Cadet with a snow blower, a mower deck, chains, and weights. My problem is, the belt on the snow blower keeps coming off and is flipping over on the pulley on the snow blower itself. Is this normal? Also the power steering is not really power steering. Could that be a bad RAM or is there a reservoir for the power steering fluid? It also came with a cab.
Thanks John
Old 11-18-2014, 09:03 AM
Buy a new (and proper) belt for the snow blower.
The reservoir is the "rear end". Make sure you have the proper fluid level first. If that is good, then I would suggest changing the Hydraulic Filter.
Old 11-18-2014, 11:47 AM
Group_44's Avatar
Group_44 Group_44 is offline
Take a look at the Technical Library section of this forum for the manual on your blower, it should show you the proper installation of the blower belt, it should be right side up in all the pulleys.
http://www.onlycubcadets.net/forum/s...ead.php?t=7435
Could be a 450 or 451 blower depending on the serial number of the tractor. Make sure the tension pulley and the tension spring are in their proper position. The manual will show you this too. The fluid for your power steering is the same fluid for the hydro drive and hydraulic lift, it can be checked with the dipstick for the hydro system under the seat. Where is the "growling" coming from, the power steering cylinder or the hydro pump? Welcome to the forum! Congrats on the Cub.
Old 11-20-2014, 10:52 AM
Not sure on where the growling is coming fromI'm thinking it's in the pump I've got a filter and some new hydraulic oil to change that in the rear end this weekend I bought a new belt also to put on the snow blower and put that on the right way and see if that works other than that the tractor runs good I did get a gasket set for the carburetor they don't sell a complete set repair kit but I'm going to rebuild what I can in the carburetor see if that helps it run a little better also. Thanks for the responses. One of my local small engine parts stores told me it was unlikely that the steering cylinder is bad. He said he rarely has seen them go bad but I think I trust guys that have owned them more
Old 11-20-2014, 11:01 AM
John
Why are you rebuilding the carb?
Old 11-20-2014, 11:04 AM
You may find some of this worthwhile.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Old 11-20-2014, 07:25 PM
Well the idle set screw is bottomed out and it won't idle right
Old 11-22-2014, 09:58 AM
Strange thing happened when I got home last night. I started the tractor to put it in the garage so I can change the hydraulic oil today and I have no hydraulics at all and no growling either. Any ideas?
Old 11-22-2014, 10:03 AM
Unhappy 1995 2182
A strange thing happened last night when I got home from work. I started the tractor to put it in the garage so I could change the hydraulic oil and filter and I have no hydraulics at all and the growling I had last week when I parked it there is gone. Is there a belt that drives the hydraulics?
Old 11-22-2014, 10:16 AM
Pump is shaft drive on a 2182. If it was outside I'm wondering if you have enough water in the oil to have frozen in the filter. I'd suggest that you push it inside and warm it up and see what happens.
