Old 11-22-2014, 10:54 PM
BooBoo BooBoo is offline
Default Cub Cadet 70 key
I picked up a CC 70 today.The key is broken so i need to get another one. My question is, if i buy a original key off Ebay, do i want one just for a 70? Or, will any narrow frame key work?
Thank you
Old 11-22-2014, 11:28 PM
all the older cub keys are the same.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-22-2014, 11:32 PM
As all IH tractors.
Old 11-23-2014, 12:35 AM
bocephus1991's Avatar
I got the spare keys of all the IH tractors we used to own and I found the old spare to my 1200 that has the IH on it! That's the key in my 1211 now.
Brian
Old 11-23-2014, 03:22 PM
LFR2014 LFR2014 is offline
The key I have for my cub is a artic cat 370z key. It has a nice rubber grip and isn't so hard on your hands. Just a helper
1971 Cubbie 127 and home made cart. 1944 farmall h all restored
1968 John deere 110 w/ haban 48 in model 426-a sickle bar mower still in work clothes
Old 11-23-2014, 04:18 PM
If that's the case then your tractor doesn't have the original ignition switch in it.
Old 11-23-2014, 06:22 PM
sawdustdad's Avatar
As all IH tractors.
This has always surprised me. Every key the same. My first thought is why even have a key, but I suppose it allows you to keep the kids off the tractor when you don't want them playing with it!
Old 11-23-2014, 07:55 PM
Most all the old tractor companies and equipment companies did the same thing. IH had their own, so did Deere, Case, AC, CAT, and so on. Never changed. The keys did, but the code didn't. You can still have one key for all your equipment. Like when Case and IH merged, they went to a key and stayed with it. I'm not sure if the old and new Magnums still use the same key, they might have changed code.
Old 11-24-2014, 07:04 AM
boyesreef boyesreef is offline
my 1450 key is a john deere key, or i can start it with a screw driver, or tool box key, or paper clip. its just a standard tractor key.
Old 11-24-2014, 03:02 PM
It's and original switch they just interchange as that if you have enough keyed equipment chances are you have a key that will fit. It's very generic
