Old 11-24-2014, 10:45 PM
overtime hank's Avatar
overtime hank overtime hank is offline
Default Elec PTO noise
I have a 1650 that I only mowed with well this year its time to hook up my snowblade. I took off the deck,mule drive and belt. Installed blade, this was the first time I ever took off deck and mule drive. when I started the tractor and turned it off I heard a noise coming from the pto I never heard before it sounded like the bearing was free spinning and making the noise. my question is,is this normal
Old 11-24-2014, 11:03 PM
Yes this is normal. Since there is no drag on the Pto pulley with no belt, it will continue to spin when you turn the engine off and sound like a turbo winding down
Old 11-24-2014, 11:26 PM
thanks im glad to hear that. Am I supposed to oil or grease the bearing
Old 11-24-2014, 11:31 PM
No, no.... this is not normal. There is a brake on the PTO that should keep if from spinning when it's off. Sounds like the brake is too loose. It is the 4 nuts that hold the square piece on the PTO. Just snug them up a bit. They should be tight enough to keep it from spinning, but not so tight that they engage the PTO. If it doesn't quit, you may indeed have a bearing going out.
Old 11-24-2014, 11:40 PM
thanks Jmech Im gonna go out and check those bolts. It sounded scratchy when winding down and I see they are a pricey item.
Old 11-25-2014, 12:21 AM
Well I went out to the barn and saw the 4 nuts started just tightening them down and noticed there are springs behind them,glad I only tightened one took it back out and tried to tighten them evenly. Seems no more noise.Is it critical to have the nuts exactly even
Old 11-25-2014, 12:37 AM
It's ideal. I'm not sure "critical" is the right word. "Ideal" is better word. I just try and either count the revolutions or measure the distance.
Old 11-25-2014, 12:44 AM
That's what I tried to do and when I spun the pulley, it seemed to drag on different sides more adjusted other side and so on till it felt even.I think I got it, thanks for the late night help Jmech
Old 11-25-2014, 12:23 PM
Your welcome.
Old 11-25-2014, 12:26 PM
Jon doesn't need sleep, he's powered by nicotine and caffeine.
Pap's 100
Restored 108
1211 Dual Stick
1050
