Old 12-03-2014, 06:11 PM
kostendorf's Avatar
Default Help I need an electrician for truck lights
I'm trying to put led lights on my flatbed Nissan. My problem is I'm supposed to hook up the brake wire to the blinker wires but there is only one brake wire and it won't work that way. It works like emergency flashers when a blinker is on.
Old 12-03-2014, 06:34 PM
Now, what are you trying to do Keith?
Are you replacing the tail lights with LED's? Or adding lights to the system.....
Old 12-03-2014, 06:39 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Did you convert this to a flatbed? What type of lights are you replacing? Factory or trailer type lights? You may need a trailer light converter. Also leds won't flash correctly with a standard flasher, due to the low current draw.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-03-2014, 07:07 PM
kostendorf's Avatar
I'm replacing trailer lights. It is homemade. Will this converter make the brake, running and blinkers work.? It was set up before for just brake and turn signal but was not bright because the brake wire was attached to the running light wire.
Old 12-03-2014, 07:20 PM
Billy-O's Avatar
Billy-O Billy-O is offline
If it's trailer lights, usually you'll have left turn signal/brake light and right turn signal/brake light. The turn signal feeds also are feeds for brake lights. You probably won't find a straight up brake light feed.
Plow blade
#2 Cart
QA36 snowthower
Old 12-03-2014, 07:21 PM
Calvins66Cub's Avatar
I think you need an adapter. You car has separate brake/turn signal lights.
They make a trailer adapter for that application combining those separate light wires into one brake/turn wire. I would be careful trying things. You might
back-feed the system and mess something up.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 12-03-2014, 07:34 PM
Not on a Nissan. Like Calvin says below, the brake and turn signals are separate. On his truck, it does have a single feed for brake lights.
The flasher shouldn't be an issue if its just on the trailer. If eliminating light bulbs, then yes, that is true.
He won't mess anything up, except for at the most blowing a fuse. Yes, all of you who said he needs an "adapter" is correct. It's not really an adapter, it's a little box you wire in. It contains diodes so that the turn signal and brake feed can be sent to the lights without back feed.
Now, just like anything else, we need the year and make of your Nissan truck. No reason to keep guessing until you know what your working on Keith. You know the drill..... Info please!!
Old 12-03-2014, 07:54 PM
Shrewcub's Avatar
But... they are going to be the rear lights on the truck. Just having the front bulbs for the turn signals will flash fast. It may not be too fast to be a problem though.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 12-03-2014, 08:04 PM
Billy-O's Avatar
I'm confused....my marbles are all mixed up.... this Nissan.... is it a truck or a trailer?? A little slow upstairs today!
Plow blade
#2 Cart
QA36 snowthower
Old 12-03-2014, 08:19 PM
A Nissan is a truck. A truck that he pulls a trailer with.
