Hi,
today i have a Question, what is the best Battery for the Garden Tracror with the Kubota D-640? I made the Battery under the Seat of my 782 and the biggest one, that will fit, is a 30 AH Battery with 300 A Cold Cranking, thanks, mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!! |
you can get a gel battery from interstate there for wheel chairs but there great for garden tractor's the couple sizes, but the one I use is the same size as a regular garden tractor battery, that one has 600 cc (cold cracking). I bought a new one for 75.00 in spring they make one about the size of a motor bike but I not sure what the cc is on it. you might be able to get a blem with is a good used one for 35 in garden tractor size. hope this helps.
Georg:
Get the biggest battery you can fit into your battery compartment. 400 or more CCC (Cold Cranking Amps) [Holen Sie sich die größte Batterie, die Sie in Ihre Batteriefach passen. 400 oder mehr CCC (Kaltstartleistung)]
The battery in a 2182, which is the gas Kubota, came with a battery that had 500 cold cranking amps. I wouldn't go with one any smaller than that for reliable starting cold. The battery group size was 26R.
thanks for reply.
Is the Electric System of an 782 D compatible with an Battery with AGM Technology? I can get a Power Star Battery with 35 AH and 430 CCA, here in Germany for a good Price, mfg Georg
The gear reduction starter and glow plug upgrade will help a lot in regards to battery size. I don't have to crank my 1782 near as long with them. It cranks the engine faster while using less current.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
