Old 12-13-2014, 08:59 PM
blee128 blee128 is offline
Default Valve/cam ?
I have an early k321 with the different size valves and was told to put an 18hp can in it until we discovered the smaller exhaust valve should I still do it or not. I'm still learning this whole mechanizing thing so you guys tell me what y'all think
Old 12-13-2014, 09:26 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I'd stay with the small exhaust valve. a LP head would fit right on. I've never figured out Kohler's theory with same size valves. in most engine's the exhaust valve is smaller. I'd get a regrind from one of the cam grinders, they are better than the K361 cam. the 361 cam is getting pretty pricy to.
Old 12-13-2014, 10:08 PM
I already have the cam it came with the mower when I bought it im just trying to figure if the power gain will be worth the trouble
Old 12-13-2014, 10:34 PM
dvogtvpe's Avatar
are you going to pull with it? there's some gain but to get the most out of it you need to do some other work as well.
Old 12-13-2014, 10:37 PM
yea its a pulling tractor sorry I forgot to mention that
