Old 12-18-2014, 10:53 PM
Default 2072
I may go look at a 2072 this weekend, can anyone tell me what the biggest problems with them were/are?
Thanks
Old 12-18-2014, 10:59 PM
Shaner Shaner is offline
Flex disc couplers on the drive-shaft, cracking transmission mounts, magnum fuel pump diaphragm leaking into crank case. Trunnion, and some with power steering valve leaking issues. But...they are one stout machine! I LOVE my 2072.,almost enough to bring it in the house
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 12-18-2014, 11:16 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Shaner is right. The front trans mounts would be the first thing to look at. The rest is easily fixed. Well the steering box would be a pain and Sams braces would take care of the trans mount. But they are good bargaining points if there is a problem.
I love mine so much I spent a bunch on it. And I ain't done yet!
Good luck!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-19-2014, 06:48 AM
cubfan's Avatar
cubfan cubfan is offline
Finding one that the owner is willing to sell would be the biggest problem with them.
Old 12-19-2014, 07:19 PM
gdheck's Avatar
gdheck gdheck is offline
Another problem is the non-adjustable carburetor. There's not a lot you can do with them. You can replace the throttle shaft and put in a bushing so it doesn't lean out the mixture so much.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
