Old 12-19-2014, 10:21 PM
GERKS 149 GERKS 149 is offline
Default 1811 vs 1250
What are your thoughts on replacing my 1250 for an 1811 with a 50 deck? My 1250 has lights and I converted to hydro lift. Also rebuilt the engine 4 years ago. Both in really nice shape. Can purchase the 1811 for a nice price.
Old 12-19-2014, 10:27 PM
ccannon222 ccannon222 is offline
I have a 1250 manual lift and a 782. I'd take the 782 over the 1250 any day. The only things the 1250 have over the 782 are better fuel economy and the engine is cheaper to rebuild.
A. 782 is very similar to a 181@.
Chris
Old 12-19-2014, 10:37 PM
No comparison. Can't go wrong with the 1811. Pinnacle of the GT's. Only thing that would have made it perfect would have been power steering. Diesel motor would be cool, but then it would be a 1512.
Only difference between a 782 and an 1811 is the Mag engine.
Old 12-20-2014, 08:13 AM
yeeter yeeter is offline
I have had three of the quiet lines, a 1450, and two 1650's.
And also an 1811 and a 782 (similar tractors).
The choice was on which ones to keep, and I choose to keep the 1811 and sold the quietlines. I felt the 1811 is the best of the lot. Smooth running. Lots of little things sorted out (oil filter, fill plug for hydro, oil light, disc brakes (for a plan to add steering brakes), metal sheet panels).
Having said that, some people prefer the older tractors. And the fact that they were made by IH. The twins on the 1811 are more expensive to rebuild if needed. Am sure there are other views/opinions, no absolute answer either way, just depends on what you like.
(of course this forum is going to suggest you need both.... )
Old 12-20-2014, 08:41 AM
Keep BOTH....
Old 12-20-2014, 08:57 AM
j4c11's Avatar
j4c11 j4c11 is offline
So a 2072?
Old 12-20-2014, 09:22 AM
gdheck's Avatar
gdheck gdheck is offline
Keep BOTH....
I second that. If you can keep the 1250 for play and get the 1811 for mowing. You'll be surprised how many uses you find for the pair. I think I've had 4 going at once.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-20-2014, 09:51 AM
Originally Posted by j4c11 View Post
So a 2072?
No, 1864 would be closest. But it had the plastic....
Old 12-20-2014, 10:38 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The 1811 also had the adjusters on the front axle,which was nice when the pivot pin started to wear. Maybe the CCC 782s had it, IDK?
Edit: OP Keep BOTH.... and buy a few others too!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-20-2014, 11:14 AM
Gerks, once you own one of the twin cylinder machines you will see what everyone is talking about and that one looks nice in the picture. The 1811 was one of the best built machines made. Not all 18XX's have the axle adjuster but the later ones do but that is also a simple fix if this one doesn't. As with all the aluminum rear machines, check the rear bolts.
If you get the machine you may want to add one of the cyclops rear frame covers to help with the bolts working loose like I did on the 1811 I once had if it doesn't have the cat 0 hitch. The SamMac brace would also be a great add also.
Good luck and go get it!
