Old 12-21-2014, 07:00 AM
yeeter yeeter is offline
Default 1811 rear end, couple questions
The hydro fluid on this was overdue for changing, so yesterday it got the service. Definitely was worth doing.
I had different gallon bottles of hydro fluid, and going onto the second gallon the color was different than the first that went in. The first was a red tint/color to it. The second was more clear, and brownish.
Otherwise the bottles looked the same. I am assuming there are different versions - does anyone know the differences and more importantly the implication of mixing the two (ended up being about 2/3 brown version and 1/3 red version).
Then was pulling some pretty big logs yesterday - 2ft diameter pine segments through rocky wooded terrain. The chain was just hooked on the regular hitch but I can say Im not going to be very delighted if I break the hitch (bolted into the aluminum housing) - it was taking some pretty good jolts.
Would like to hear your opinions on a) likelihood of busting the hitch plate off (likely stronger than I think) or b) an aftermarket plate that bolts to the frame? (xtreme or a cyclops part?) or c) swap out the rear and put in a cast iron one (which I have an extra lying right beside the tractor). Course even with CI, a and b still apply...
Old 12-21-2014, 07:33 AM
(A) The Hytran done it's job and absorbed the moisture within.
(B) Someone previously mixed something else and you had a "cocktail".
Old 12-21-2014, 07:53 AM
The brown colored stuff was brand new purchased that day.
The red was left over from a previous purchase. I supposed there is an outside chance I had some pretty good used fluid that I had put back in the bottle (red tint), but I dont think so... (just not the type of thing I would do). The red stuff I had mail ordered from a sponsor here.
Now wondering if I mixed used with new.
Old 12-21-2014, 08:40 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Was the "brown stuff" the same part number as the other container left over from a previous purchase?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 12-21-2014, 08:51 AM
Not sure I can determine part number. The containers are the same. But the brown has a little sticker with some numbers (I thought maybe dealer part number), will post it later
Maybe the question is, what color should it be?
Old 12-21-2014, 08:52 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Hydro fluid? What brand and type of fluid are you using?
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 12-21-2014, 09:21 AM
Cub cadet brand, 'hydrostatic transmission fluid'. Containers the same. One gal purchased from sponsor on this site. The other purchased from local dealer.
(Unless as previously noted, I got some of my own used fluid mixed into the one container).
Old 12-21-2014, 10:10 AM
FrankF3's Avatar
I was concerned you may have gotten some of the synthetic stuff that is out there for the new models.
Old 12-21-2014, 10:30 AM
Is this the fluid you bought...??
HyTran
Old 12-21-2014, 10:53 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I just did a drain and fill/filter on the 2072 the other day. I just wanted to get the ISO and blue dye out the PO had put in. I had 5 qts of hytran that I put in and topped off with motor oil. This cocktail will be in until I install a 3point and do a Sam Mac service to the rear. I noticed globs of moisture in the previously opened and the factory sealed gallon that I opened. I got this fluid with the purchase of another tractor. This will be the last time hytran ever goes in one of my machines!
To answer the fluid color question, it was reddish brown but not red like atf tho. I really only saw the red when it was in the white container.
Now its blue
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
